84BuickGNYorkPA
Daily Driving Buick V-6 Turbo's 1979 - Present
- Jul 5, 2005
Here is a old picture of the stock fuel lines, one of the 1st things to put on when assembling the accessories up front. Kirban's and Highwaystars both sell the stock set of lines. On my return line at the frame (the old line that is on your car now) I had to drill out the inside diameter (make the through hole bigger) so I could turn the fuel pressure lower. I had a cheap set of drills which worked good, I opened it up as much as I could, when the crimp was made at the connector the restriction was substantial enough that I couldn't get enough flow to lower the pressure at the regulator.
