robbyredneck
- May 31, 2006
thanks for looking guys and any input will help. first off my car has modded ecm with trans plus and 72lb ls1 maf. a couple of weeks ago i got my laptop so i could do a little fall tuning. i plugged in turbo link and all looked good. i let the car warm up then set my translator+ to what i thought was 3.5 lean idle but the trans + is mounted upside down and i turned it to the not used setting and the idle went to crap. i then realized what i had done, shut the car off, reset and started and it was fine. took the car out and tuned wot timing and a little alky. came back idled car with t-link on and same thing. it runs like the choke is on! i recorded the bad idle and later noticed the maf readings went from 2 on a good idle to 7 on the bad.the ecm showed about every code in the book and had a monster voltage dropout when they set. i even unscrewed the iac to lean the mix out and the choppieness went away and it idled at about 2000 rpm. i sent my ecm back to full throttle and they replaced the chip and bench tested. i am still waiting for the trans+ to come back. i checked the grounds and all of the ckt to the ccci. also a couple of weeks ago i had a weird burning rubber smell under the hood. i found that the previous owner had cut the connector to the egr system and the pink/bk wire was shorting on the intake.(trouble shooting at night has some advantage). i checked maf on my 00 camaro and it seems to be ok. so while i wait for my trans + i figured i get some input.
