turbodaniel
clean air 1
- Nov 14, 2007
I have a GM sensor off a 2003 Tahoe and have read that some installs Y off on the return line. Is this necessary or can it just be spliced in? I am running a magnafuel 625 pump with an lines
Thanks figured that would be the way to goI would y your return. Remember that the factory pump and pressure are lot less than what you will be having. All that I have seen installed have been Yed, including mine. You dont need a lot of fuel to flow through them to read.
I would y your return. Remember that the factory pump and pressure are lot less than what you will be having. All that I have seen installed have been Yed, including mine. You dont need a lot of fuel to flow through them to read.[/QUOTE
Wish i saw this before dumping big bucks on all the y fittings...any way a couple pics of install
