I would turn that screw that most people try to adjust the idle with counter clockwise a bit. As posted above this will lower the TPS voltage a bit and get the IAC off of 9 and up into the 10-30 range. Then check the BLM should be at 128. Seems to be adding fuel, may need to up the fuel pressure a tad.
