I am looking for advice on external wastegates to avoid boost spikes. My combo is in my sig below and my specific issue is a 4-5lb boost spike since installing the FMIC and having to rewhack the actuator mounting to clear the reclocked turbo outlet and the external wastegate port on the turbine side. The CPT66-BB I bought a few years back came with the external wastegate port on the turbine and the stock style actuator rod barely clears the flanged port. I’m using a stock style actuator with a bit heavier spring and a modified bracket.
I’d like to switch to a Tial external wastegate. I used a Deltagate years ago with less hp and smaller turbo, but it locked dead on 19lbs boost; no spike, no creep. So, I figured an external WG would be the way to go. But, I’ve read, and Cotton’s confirmed, that mounting it directly on the turbine housing doesn’t give adequate control. And Cotton’s no longer sells a 3” DP with external WG.
So, does anyone have an experienced opinion on the external wastegate connected directly to the turbine housing as to controllability (spikes, creep)? I’m using an AEM Tru-Boost electronic controller.
As an alternative, I was told that the DP’s (with external WGs) sold these days don’t fit well. Any opinions there?
Thanks!
Thanks!
