BlackBettie6
boost addict
- Nov 23, 2007
hey im new to the site but have been using it as a reference for over a year, you guys are the balls!
i have an 87 gn with t-tops (and a twisted frame) th350 shiftkit, lots of upgrades done when i bought it . i am running lean but sommetimes get a smell of unburnt fuel. ive sprayed the intake ,vac lines and intercooler plumbing with TB cleaner found one leak on drivers side. i am currently taking out egr valve ,looks like bad gasket, should i leave egr out and block or will i get probs? the symtoms i was having was rough idle (may be cammed?) slight high pitch wihstle during accel and past half throttle it sounds like somone is beating a drum under my hood. last problem is that on the highway in top gear (3rd) its seams like it shifts into one or two more gears and dogs bad also will not down shift (cable works). i turned the boost down to about 14 and have been babing the beast. No codes and i know the light works. and help would be greatly apreciated! thank you !----kyle
