use a cap on the tee or eliminate the Tee and run a new vac line straight from the white /black check valve near regulator to the black check valve at the firewall (to keep the hvac vents , heater valve and cruise working)
removing the egr solenoid controller wont result in a check engine engine light or any codes unless you're on an old chip based off stock or stock chip
