i have no problems.. and im heading to the track very soon, and will post up video..
So far i couldnt be happier, very satisfied, i have over 500 miles on them and still leak free
How Do I Get The New Headers.the Ones I Got Do Not Fit I Want To Exchange
Question? Do 3 1/2" China made down pipes have as much material/labor in them as a complete set of TA style headers???
I installed a set for a customer. They were not even close. I had to cut the crossover pipe and weld together. The slip joint was a joke. The cross over hits the oil pan with a girdle so pan was modded with a hammer. The turbo flange was clocked wrong downpipe will not fit. Had to cut off the turbo flange and re-clock. Turbo sits to far to the right for ATR style downpipe so I now am re-doing the down pipe. Main pipe on the right side lays against a stock starter solenoid. Anyone else had these problems or am I the lone ranger? Nice headers for the money but if you dont own a tig welder and have a little skill good luck.
If you look close at the pic the turbo is clocked wrong. If they fix this then it will go a long way to helping the DP. TA had a few headers that went out the door with this flange problem. Guess thats the headers they knocked off.
I know someone else who had that problem with TA headers. Mine are fine though.
The problem with the China-made stuff, as far as I can tell, is that they're like a box of chocolates. You never know what you're going to get. Maybe 70% of them are good, but 30% have some sort of icky cherry goo or other horrible tasting stuff in them. But people keep buying boxes of chocolates because some of them are good. Unfortunately, the vendors get the box of chocolates and the consumer only gets one piece from it. Some get good ones, others don't.
This is a bit of a digression but.....how come all the china-made stuff consists of multiple pieces welded together whereas the US made stuff is mostly single pieces that are bent properly? I noticed this with the downpipes and the exhaust systems. Not sure about the headers.
Jim
, I was prepared for some modding, I have had to mod expensive products as well, I guess it goes with anything aftermarket.
