Yesterday afternoon I was able to park the GN on a Mustang Dyno for quite a few hours. Before I begin, I must first thank Richard Clark to letting me have the Dyno to as long as I wanted. I highly recommend going to the Richard Clark/Kirban/GM Turbo 6 meet http://www.turbobuick.com/forums/national-racing-events-info/256735-gm-turbo-6-october-meet.html it’s going to be a meet like no other. Also I’d like to thanks Pat Broughton (SloGN) and Jim Anson (V6power) for babysitting me while I was dyno’ing.
Okay, so I was able to make about 20 pulls on the dyno (I have all of them datalogged with my Powerlogger). We started with the boost at around 16 lbs and ended with the boost around 24 lbs (too much). My whole purpose of these pulls was to mimic runs at the track and not necessarily high HP and Torque numbers, so the first thing was I didn’t lock the torque converter. The second thing was I shutdown at 90 mph (my ultimate 1/8th mile MPH goal).
In summary, my lowest HP pull was at 223 HP with a torque in the high 200s. My highest pull was 297 HP at around 360 ft lbs torque. All of them were in the 4100 RPM range with a couple of exceptions. All pulls were with 93 octane with methanol (Alkycontrol).
A lot of my runs seem to consist of 2 things, knock when I went to WOT and knock at or close to the end. We basically figured out the knock at the beginning was because the TA49 was spooling up like crazy when I hit the gas. We tried several things to eliminate the beginning knock, but found the magic bullet was the spool fuel parameter of the SD Chip. Once we started increasing that value the knock went away. We were never really able to figure out the knock close to the end of my pulls, there was about 1 to 2 degrees of knock that seems to always happen at around the 88 MPH range. The last few pulls we tried tuning the car at 24 lbs of boost, but no matter what we tried the knock would not go away. We figured that the TA-49 was heating up the air to the point the Alky and 93 octane combination was at its limit. So basically we re-enforced what I figured out at the track that my max boost is now 23 lbs.
It seems that my next logical step is to upgrade the TA-49 with a bigger compressor. That will help me make more boost without cooking the air and also add some turbo lag that it seems I need. Having instant boost is great if you want to cook the tires, but makes it really hard to hooking up at the track.
