If swapping u-joints, mark the rear of the shaft in relation to the axle and the front of the shaft in relation to the yoke. To remove the shaft, unbolt the straps at the rear axle and just slide out of the trans. You may loose a little tranny fluid, but not much. When re-installing, use some blue loctite on the strap bolts and torque to 16 ft-lb.
