Originally posted by Silver97Camaro
Oh by the way what are your Stang's running SprchrgdPony?
Which one? Have 3? Well, 2 after June 5th.
94 has gone a best of 13.5 @ 114 w/ 2.2 60' <~~ 11 sec mph, on 6cyls (stock block, leaned out and melted cyl 7,8 pistons), stock injectors, FMU, 6# Boost (stock SN93, no Powerpipe), Catted H-pipe, 295 Comp T/A's... now it has a SN93 VR4 that makes anywhere from 6-9# Boost with 36# Injectors, custom chip, X-pipe, 4 Inch Powerpipe, and a few other things. The setup is good for mid 11's all day.
No times will be discussed for the 87, but it runs very strong for a N/A 302 and ALOT stronger with the nitous. Will run with alot of GN's on motor alone
88 is a project car right now so there are no times, but the setup on motor is good for 13's...12's on motor. But its a daily driven convertable, and doesnt need to go faster then what its gonna be built for.
New project after the 94, is going to be a 87-89 LX with a rebuilt Turbocoupe motor. Should run in the 13.xx area after its built..then into the 12's with a bit of nitrous.
Any more ?'s ?
