Well the new motor is in the car, and things are going about as typical as they ever do.
Look at these pics and reassure me about some wires...
http://www.oldwestracing.com/images/gnwires/wires1.jpg
http://www.oldwestracing.com/images/gnwires/wires2.jpg
http://www.oldwestracing.com/images/gnwires/wires3.jpg
This is the part of the harness that runs down to the starter.There is the one wire with the small ring connector that goes to the small post. Then there are the other (4) wires. Do they all 4 go to the large post? Three of them have identical ring connectors but the one (second from the right) is similar, but a little smaller overall (same ID though). I just need reassurance that they all 4 go to the large post on the starter.
Also, there were the 4 ring connectors with the star washer built in that are supposed to go to ground, right? Two with two wires on one connector, and two with only one wire. All four are ground right?
I've evidently hooked something up wrong or got a short somewhere. Just figured I'd start with one end and go to the next.
