I have a box 015013
I have spark, but no output on the injectors
I have a ground at c14 and d14 with ignition on, and it pulses with a test light when cranking, but have nothing (no + or -) at c15,16 and d15,16 when cranking
The supposedly ran before we swapped the new motor, but I don't remember, it was 3 years ago....
It uses a jumper board with red wiring on it if that helps.
Am I missing something, or should the injectors fire if the ignition is firing, are they both run from the crank or cam sensor ?
Any help would be greatly appreciated,
Thanks you very much!!!!!!!
