IMHO if you don't have a significant leak at that point, putting a gasket in there (no matter the type) is an extremely bad idea. The one thing putting a gasket between the turbo and header will certainly accomplish will be to warp both surfaces, pretty significantly as a matter of fact. The bolts on the outer circle of the mating surface and the extreme heat will pull the "ears" toward each other and the surfaces will NEVER again work without a gasket being required. Until the surfaces are made flat again.
I use ultra copper (thin surface) and have never needed a gasket. Not there or the header flanges.
The turbo gaskets are nothing more than a band aid fix for those that don't want to bother lapping the surfaces with a file.
If your headers leak, one probably has warped header flanges. Can easilly be fixed by a machine shop.
If your turbo/header flange leaks, the turbo flange and or header flange is also warped.
Although the turbo/header surface rarely warps on it's own. Many folks that buy the gasket for that surface do so on bad advice or they just think it's a good idea at the time. Once installed the damage is done, they are now warped.
About the only reason for any leakage, warping to occur there (assuming a gasket has never previously been used) would be a new turbo with a less than ideal surface.
