I installed a set of the LT1 valve springs on my otherwise completely stock turbo motor about 5 years ago. This was during the craze where all the turbo vendors were saying that these were the springs to use on the turbo motors.
I had a spare set of these springs tested for open and closed pressure ratings and they were all over the board, varying from top to bottom by as much as 20 lbs of seat pressure.
My question is this: could the installation of these LT1 valve springs hurt my performance?
The reason that I ask this question is because I have been fighting the fact that with all the parts in my signature below, I still can only achieve 109-111 mph in the 1/4 mile. With the parts, I've been told that I should get 113-114 mph.
I hit 111 mph just a month ago with this combo, which is the fastest that it has ever gone, so I most likely isn't because the springs are old and need to be replaced. They probably only have 20K miles on them since they were installed.
My goal is to get this thing to run a high 11 second pass without having to port the heads or add an aftermarket camshaft. I know that this can be done, since so many others have succeeded.
Thanks for any ideas and/or assistance in advance!
