Sorry for another cam thread guys but i would like some input on which brand to go with. My #3 ex lobe is shot on my comp 212/212 FT and i am planning on going back in with a 206/206 (not set in stone, open to suggestions). I have unported heads and really just wanting a mid 11 sec daily driver right now. The real kicker is I reused this cam on a fresh 2 year long rebuild without doing a true cam inspection and feel like a complete retard.
The drivers side tick I had prior to rebuild was right back after about 20 miles on this motor and turns out it was the push rod up/down play tapping the rocker.
Ive been reading a lot of threads and it seems that many experienced TR guys feel the problem isnt necessarily FT cams...but the decreased quality control on aftermarket vs OEM cams and or lifters. So are their any brands you would consider better quality than others?
Also not interested in a roller setup for this motor. I plan on building a separate 10 sec roller motor in the future and would like to just do a FT swap on this one for now.
Thanks for any advice folks I really appreciate it.
On a side note, i did use dino with zddp on start up then changed after initial breakin with the same. I bought this car with 5k miles on motor rebuild and blew at under 10k miles. I ran reg valvoline without zddp and am pretty sure the previous owner ran synthetic with no zddp.
