I have had a issue with my brakes going soft. I assumed it was the powermaster and/or accumulator ball possibly the switch. I ran it thru the decompression and had my friend pump the pedal 10 times ign off. I observed the brake fluid resivour shooting fluid out the side. It appears that the rubber gasket is fitting properly, but it might not be secured tight enough. Would this be the issue not allowing pressure in the system? Has anyone ever had this issue, and a remedy? thanks in advance
