I've been throwing bad boost solenoid codes and have had trouble keeping a steady boost PSI. Before it would be usually around 17psi, but eventually creep up to 19psi after holding WOT for an extended period of time. I decided to hook up the turbo "tuner style". I ran a vacuum line straight from the wastegate to the outlet on the turbo.
Now when I floor it, I only get 10psi.... it will stay at 10psi for a short amount of time, then go up to 12... then higher.... I'm used to it going straight to max boost without that lag. I want to tighten the wastegate rod, but I'm afraid it will go to 15psi then creep up to 20 or something....
I have a Precision .63 exhaust housing and the TA-51, 3" THDP, and an adustable wastegate. I've been told that the TA-51 shouldn't have any problems with the hole the puck on the THDP covers....
Should I turn up the boost by tightening the wastegate? Think my wastegate may be going south? This doesn't have to do with the computer anymore so I don't know what to think
