Jan Larsson
- Nov 22, 2001
Well not the best of days ... nice car show down south (1 1/2 h drive smaller roads and through one smaller city) ... so got it all prepared night before then drove down this morning.
Couple of red lights and smaller cues on the way down there when we got close then cues closer to the venue but nothing serious really ... however did notice the coolant temperature rising (scanmaster and temp gauge) the it did rise drastically into red ... 245 or so F ... and I lost all the coolant.
Stopped let it cool down as much as possible then on of with the engine until we could make it into an area to stop and properly look at it and the S-hose (bypass hose) at the waterpump end had popped off ...
Anyone had this happen? I suspect it leaked coolant and when I lost enough to raise the temperature the pressure built up shot the hose completely off and I had a nice (not) fountain emptying most of the coolant across the engine.
Looking at the waterpump nipple it's slightly coned and nothing to grab hold of the hose/clamp at all so can see it possibly shoot off (or slip off over time); anyone had problems with this and if so what was the cure (more than tightening the clamp as much as you can).
Will remove the radiator and flush the engine / radiator properly and reinstall the S-hose.
I hope I did not damage the engine due to it being possibly overheated ... oil and everything else looks good ... and we got the hose back on good enough to refill the coolant with water and drive back home and had no issues with temp rising more than what's normal when stood at red lights etc.
Anyway not the best of days and do hope nothing else happened to the engine (only got the 1500 miles since complete rebuild years ago).
