Wells, I believe you may have taken my last post wrong (not bad advice)
I was not saying you were wrong, just trying to reassure Ryan a little. Some folks make way more of a problem than it needs to be. Belt dressing tends to complicate things, because it masks symptoms temporarily, and it's messy, but doesn't really accomplish anything. Sounds like the tensioner* is on it's way out. If it is cocked, even a little, it will make the belt squeal, and all the toothpaste, belt dressing, or even
salad dressing in the world won't stop it.
when you brush your belt with pepsodent.
A paste made up of Comet or some other surfactant would do equally as well or perhaps better, but toothpaste is easy and makes your motors breath smell better.
It's easier to rinse off too.
* Try removing the belt, and spin the tensioner by hand. The pulley should turn smoothly, but not necessarily freely. If it spins freely, or feels rough, the bearing may be bad. Most likely, the tensioner itself is worn to the point it's getting cocked, which makes the belt track cockeyed, which would be where the squeal is coming from. Tensioners do have a finite life cycle, and we replace a bunch of them on vehicles only a few years old these days.
