Anyone using the ATR external wastegate Downpipe?
BradWE4
I have a TH right now and am trying to decide if it is worth switching, considering it is going to cost in the $700 range I want to be sure it will make some kind of a difference.
I run one of there pipes that they set up for me to be used with a delta gate. If you already have a 3" down pipe then I wouldn't expect to see $10 worth of a gain much less $700.
HTH: Jason
HTH: Jason
+1 unless your DP is messed up in some way or you need to change your WG configuration in some way I'd stick with what you have.
Darn you caught me on that one.....
You see what happens when you get all hopped up on Cuban coffee, your liable to answer anything.
:eek:
Ok.. who's bringing up 4 year old posts :redface:
Oops, that'd be me that resurrected the thread:redface: ...I saw it at the bottom of the screen in the "similar threads" box when I was looking at something else and jumped on it...:D
