My guess is that two pumps in series will flow a little more fuel than one pump (maybe 5-10% more) BUT the pressure will be way more than one pump. You need to look at the pump curves to be sure!
I would probably make the stronger pump the first pump and the weaker pump the second pump. Having higher inlet pressure on the weak pump will help it flow more fuel if you keep the outlet pressure fairly low for the 2nd pump. Just be sure you have a capable fuel pressure regulator and an accurate fuel pressure gauge...ie a Procomp Autometer or equal.
You have calculated your fuel flow and pressure requirements haven't you? If not, talk to a professional. There are several I would trust...Jack (Cotton), Cal (Hartline), etc. You will need to tell them everything about your engine HP goals, engine specs, fuel, fuel system, boost goals, etc. Oh yes, be sure to buy whatever you need from the pro that helps you!
Hot Air
