I am a long-time member of TB.com and have searched many topics just like this one. I seem to be stuck in a rut with my GN which should be running better times with the mods that I have done.
In my signature below you will see what I've done. The 12.06 timeslip seems to be a mirage, since I've only been able to get the car to run this time once! Since then, the closest I've been to it is around the 12.40's at 106-107 MPH.
I seem to be losing MPH but my short times are still consistently in the 1.8's and high 1.7's.
I'm looking for some advise as to what I should look for as my culprit to keeping me from running in the 11's.
It should be known that my GN has always had a problem with running lean at the top end, no matter if I'm running Joe Lubrant chips or if I'm running Red Armstrong chips (usually rich I'm told). The 02's will drop into the 750's and 740's and sometimes even lower at the big end.
