Accel DFI 6.0 / Calmap Questions, Please Help.
xLusi0n
I have a few questions, I notice that in the Edit File mode, my IGN timing map is from 1500-5000 rpms...but when I am in Edit ECU mode (with the car on) it shows a 1000-7000 rpm map!?!?! What happened? Which one is right? Because I've been setting up my base 91 octane timing maps, based on the premise that I'm tuning from 1500-5000, not 1000-7000...I could be placing a 30 degree value in a 7000 rpm box, thinking I'm putting it in a 5000 rpm box...
Thanks for any help!
What is your Base Map Cell Size value in the ECU configuration and what is it set at in the Base Fuel Map in that file? Sounds like it's 2 different values. The one in the file is probably larger. The ignition map is scaled 1.5x the base map cell size. ie 400 base fuel map value = 600 ignition map value.
