*****the price is only $150 shipped!!!! the other prices are what I paid and what it sells for new. sorry for the confusion ***
hi everyone,
I had this since it was new in my Nissan 300zx twin turbo never any issue. but recently I had to return the car to stock because I needed to sell off my bigger turbos and supporting mods due to financial issues. I cant afford to have all these cars and bikes anymore. long story short I am offering this just incase anyone here has any tuner cars that would be interested in buying it. Im new here and still educating myself on tb's. but, im pretty sure that this is not the ideal device to tune turbo Buicks with. but I could be wrong.
the neo is in perfect working condition. it has some scratches and signs of wear and tear but it functions perfectly. it also has Velcro on the back of it. (I will remove it and clean the surface if you want).
I paid $549. for this new the week it came out. now it sells for $495 on the apexi website.
now this functions 1000% as good as the first day I got it. and I stand behind it. yes im new here but I am a stand up person and stand behind everything I do and sell. I openly give you a 15 day return refund offer from the day its delivered. if you are not happy with it.
now please note that this is for the actual neo only. no box, no instruction manual (you can download them from apexi website free), no extension harness (this is why im selling it so cheap because it got misplaced. you can buy it on the apexi website for $27. or you can just make one yourself which is what I recommend. but it does have the initial harness that comes out of the unit itself.
what you see in the pics is what you will get.
now im going to sell it cheap for $150 shipped obo anywhere in usa. via priority 3 day with full insurance and tracking. I feel that's a fair price. hopefully someone on here had a nice tuner that they can use this on. Lord knows I can use the money lol.
thank you for reading this and have a blessed day!!!!!!!!!!!!!!!
specs below form website
actual pics
The AFC Neo marks the newest edition to the world famous Super AFC line of piggy back fuel controllers. Building upon the powerful AFC Neo, the AFC NEO has taken piggy back style fuel control to a new level. The AFC Neo boasts an incredible 16 points of user definable fuel correction. VTEC control has also been incorporated for Honda/Acura applications. A complete monitor mode is also available to keep the driver/tuner informed of critical engine data, such as: RPM, throttle, battery voltage, correction %, air flow%, pressure (kpa), and karman sensors.
The AFC Neo is the industry standard for sub computer fuel control. The AFC Neo is designed to fine tune and "squeeze" power out of existing engine setups by allowing the user to modify the fuel curve with precision accuracy. Since the act of simply bolting on performance products does not make horsepower, the AFC allows the user to calibrate the fuel system in accordance with performance upgrades as they are installed. The AFC modifies the air flow meter/ pressure sensor signal voltage going to the factory ECU (Engine Control Unit) to change the amount of fuel injected. The AFC utilizes a Color FED (Field Emission Display) to display critical data in three different modes.
The AFC, while not completely universal, comes pre-programmed with 28 of the most commonly used air flow meter (hotwire type), 21 pressure sensor (map sensor type), 8 air flow meter (flap type) sensor maps. By setting the AFC to one of these programs, the user is able to adjust injected fuel amounts by +/- 50%. 8 or 16 user defined RPM adjustment points allow maximum tuning in 500 rpm increments. Fuel can also be adjusted for part and full throttle situations.
The Deceleration Air Flow Correction cures erratic idle problems for Hot Wire vehicles equipped with an open atmosphere blow off valve. The AFC can also display an incredible amount of data including: Air Flow Capacity (Hotwire and Flap Type only), Engine RPM, Throttle Position, Pressure Sensor voltage, Karman Frequency and Air Flow Meter Correction.
The AFC Neo displays data in three different modes: Numerical, Analog, and Graph. Numerical Mode allows the user to monitor up to four different parameters in numbers and also shows peak hold values on demand. The Analog Mode displays up to two values in an easy to read meter style display. The Multi Mode displays up to two parameters in digital and one parameter in analog. Peak Hold is also included in this function. The Graph mode offers real time graph plotting with a Ghost map trace feature built in. The graph can replay movement up to 60 seconds.
hi everyone,
actual pics
