vac system
Hi,
So your system blows out the defrost ducts only?Always? This is the default mode that the HVAC goes to when it is not receiving vacuum. It would take a huge leak to cause this always. You need to verify this is so, otherwise check the vac source and it's check valve. These systems are pretty reliable if properly supplied. More info please....
