Make sure the vacuum line in the engine compartment is connected (I think the plastic line is pink or purple). This plastic line supplies vacuum to your a/c and heater controls in the dash. You should get 18-20 inches of vacuum at the a/c and heater controls through this line. The a/c and heater controls then operate the servo's. There are 3 servo's up behind the dash that actuate the opening and closing of valves (flaps). The valves devert the air to the correct position of where air should be flowing - defrost, heat out the floor vents, air at your face or a combination of. Make sure the vacuum lines going to the servo's are connected and not cracked. Inaddition to the info already provided.
Craig
