9' cone k&N
Yes and no.
Yes if you are using a hard MAF tube OR have a bracket to support the MAF.
Here is a MAF Bracket you can make that Bolts to the Airbox mount:
MAF Bracket
Originally posted by John Larkin
Get the 14" but be prepared to relocate the charcoal cannister.
I had a 14" but was disapointed with the Venturi shape at the filter's mouth. I replaced this filter with a 6.5" filter with a better venturi with zero performance loss (deep into the 11's)
i'm talking about with the stock hosing and MAF...just until i buy a big mouth
Yeah, mine went right on the stock MAF. Easiest five minutes of my life. But you have to get rid of the airbox of course.
3" opening filter will NOT work with the Big Mouth cold air kit, I use a 4" opening filter with it. No sense in buying a filter you can't use later.
Originally posted by vettekilr
dont forget that little sensor :D
That little sensor can just lay there on the inner fender (or use the sensors harness for boost sensing for turbolink)
If the Temp Sensor did anything other that tell you if you CAI is working or not, I'd say mount it in the tube. But it doesn't.
