Sorry, that makes no sense to me at all.
If the IC is cooler than the ambient, my logic tells me, the air passing through the IC is heating the air inside the IC.
Yeah, I know you can get air cooler than ambient through fancy flow systems, but this is not the case.
If the temp drops in the IC, you will also see a pressure drop.
Besides, you will get gas pudling (Sp??) and grenade the motor (as mentioned before)
Spray pre-turbo and let small droplets hit the impellar while spinning at 100,000 rpm and see what happens. Besides, the increased mass of the fuel in the air pre-turbo will slow down the rotational response ..... I think we call that lag???
Oh yeah, I don’t have one of those power adders.
