Ok I have a 6152 with a precision .63 housing. Now I havn't been to the track since making some very good changes. They car is alot quicker than it every has been. I am thinking of changing to a .85 housing. I would really like some feedback on this before I do.
Here is what I have done. When I switched from the a te44 to the 6152 I never changed my chip. I just added fuel, and I could never get it lean enough in 1st and begining of second. It wasn't until the top of second I got the numbers remotely close to around 10.8 afr and finally in third I would get there. So upgrading the chip made a fantastic difference. I am perfect through all three gears now. The car spools instanly and I couldn't be happier with that aspect.
I also took the time to set up the suspension and set my pinion angle correctly and pre-load the suspension.
I am running a 28in tire already. I havn't really uncorked the downpipe to see how that helps. I was thinking of switching to a .85 housing and adding an electric dump. Let me know what you guys think. As always thank you in advance for your input, it is very much appreciated!!!
