Well I just got done installing some racetronix 120# low impedance injectors.
After the first start it had a slight miss at idle but it leveled out once a load was put on it.
I checked the injectors and noticed the #2 injector is noticeable quieter than the rest, I put a stethoscope on it and you can hear it pulsing but it is much weaker than the other 5.
Yesterday I was driving and even though the miss was there at idle it was VERY strong, a/f reading was on point. Then randomly the a/f reading went to shit and it was leaning out very bad.
Reset the ecu, swapped mafs, o2 sensor, iat, verified scanmaster settings, good fuel pressure, spark plugs, new coil pack...
I just dont get how it was running awesome under boost and then all the sudden its leaning out whenever boost goes over 10psi. Yesterday it was seeing wot at 22psi and it was perfect.
Today I tried getting on it and it was backfiring and falling on its face at wot !!!!!!
I have a new ignition module waiting to go in, and a ls1 maf and translator that will be going in soon. But other than that I am out of ideas.
If I need to send the injector back I will, but would one weak injector cause all this even after it was fine yesterday?
