I was out last night trying to get some new #. About 5 sec after my laptop went dead I was very easy rolling into it and i heard a pop of some sort. It didn't seem to drive much diff, except the knock gage went to red at a very low boost press. I have rmi25 in it, so i drove it about two miles home.
No bubbles in rad, no foam on dip stick.
The first thing I did notice was that when I unhooked the vac to accufab FPR no drop in FP. I am for the first time noticing a change in idle while spraying either around the rear pass side intake. Vac leak right? I have not emptied oil pan yet. Something tells me it should be a leak at intake--I always suspected an INTERNAL leak with intake, causing a 142 BLM.
Could a leak at intake cause it to go lean causing a lean cond leading to knock at low boost? Redoing the intake isnt as big a problem as head gaskets. Why would the FP not drop after removing vac line.
If it is the intake gasket will the 1200 work ok & do they come with the end seals? Will lack of vally pan matter? GN1 heads I was just getting all the right # on my TPS after hogging the mounting slots out. First time I have ever had 4.5 on tps O want to get to woodward BAD
Mart
Mart
