XFI won't start, Distributor no spark
SNKSKNR
Ok I have been pulling my hair trying to get spark with the disributor setup. I have all the pickup's on the MSD distributor ground off but one.It is set 25deg BTDC with the magnetic pickup lined up and on #1. There is a crane ignition box,and coil pack. I do have the casper adapter box for the stock wire harness and the jumper plug for the cam sensor. The only thing I know that is not hooked up is the magnetic pickup plug off of the crane ignition box. I am useing the stock crank trigger off of the GN. Where should the magnetic pickup wires be hooked up to if that is my problem. Please Help:frown:
P.S. When the wires are pluged into the distriutor only #1 will spark. This is with out the casper jumper plug hooked up.
All I have to say is thanks Cal for your great service.:smile: The car is running:biggrin:
