Just installed GBodys dual fans with casper plug and play combo and now the fans do not come on. I have Classic Fast 2.0 and the stock fan worked fine until i installed the dual fan set up. I'm sure i have everything hooked up correct. I unhooked the ECM orange wire while i was hooking up the power lead to the postive post, and then re-installed the orange wire back together. Car started right up. My question is do i need to do anything in the C-Com program in order for it to work now with dual fans?
I also only let the car get up to 176 before shuting it off, but never seen the fans come on.
