Im running an XFI to GN Adapter Module [108112] from caspers. i have this unit installed on my car as well as an XFI. i have 14.* volts coming from the alternator while the car is running. im getting this same power to the inlet of the caspers adapter box. on the outlet side of the caspers box it drops the power off to 12.* volts which is also showing on the xfi. whats causing this? i was thinking about just hard wiring the xfi to the IGN but i don't understand why the adapter box is droping the voltage down. anyone have an idea? i dont want to hard wire it but if i need to i will. the car is running fine the way it is but i just dont care to see 12.* volts when it should be 14.*
brent
brent
