xfi rev limiter
northerngn
Master Monkeywrench
it there a way to utilize the rev limit feature in the xfi to use during staging while building boost??
any way to wire in a rev limit button?
i know many launch off the msd but i also know thats hard on the crank
pulling fuel seems softer that pulling spark and all that backfiring stuff
-dan
Yes, this can be done using the XFI if you have a distributor. Keep in mind, this method will still be cutting spark and not fuel.
dang that sucks... i was playin with some of the settings and set the rev limiter in xfi real low and then walked into it
i couldn't believe how smooth the rev limiting was
as smooth as the factory gm cars i work in here at the dealer
oh well
thanks cal!
