I had the same issue when I first installed my FAST.
Open yur VE table and watch it as you shift into drive. I would suspect that as you shift the car into drive the load on the motor increases. Unless you have huge differences between your KPA readings on the vertical axis you should be able to track it the instant you shift into drive. The cell it ends up in when it dies and those to left, right top and bottom I would increase the by say 10-15% just to keep it running and then you should be able to adjust it with the brake on and in drive to an acceptable range. If the car continues to die with the above suggested increase I would continue to increase until you can get it to run in drive.
If your load doesn't change cells when you go into drive, you may need to do as HighPSI suggest and rescale, your KPA readings may be to far apart and aren't allowing enough of a micro management of fuel.
