I've got two questions. First is about the cam sync. I have an inductive cam sync setup on my belt drive. It's set at roughly 110* by the balancer. On the dashboard, it shows it at 12* at idle and when the rpm accelerates it goes up to a steady 86*. Is that normal for it to move? Why does it not match the physical setting. Crank reference is 61* on my setup. Could the polarity be backwards on the sensor? I have verified it is set correctly by pulling 10* timing from #1 and checking timing on the balancer for #1.
Second. For the life of me I can't get the driveshaft speed sensor to read on the dash. DS RPM and VSS MPH both read 0. I verified it has 5v going to the red wire and the sensor gap is set to .050". I'm going to try to move it around some more tomorrow just to be sure. Is there any way to test to see if the sensor is good?
