TURBOPOWERED68
David
- Jan 31, 2006
i have a spaghetti mess in my engine compartment and would like to remove about two FEET of extra harness that is just rolled up and looking very ugly.
Also while i am at it id like to remove any extra junk that is not being used and wire in some things that i can use.
id like to
1-Feed the MAP sensor 5 volts directly from the ECM instead of a jumper from the TPS.
2-can't remember right now.
3-the same as number 2
My main concern is that if i change the length of the harness will it change the value of the readings it gets from the sensors?
Also what would be the way to shorten it up?
Splice a few inches from the ECM plugs then solder each wire back together?
thanks guys.
id like to
thanks guys.
