Put new oil sending unit in today. She starts right up!
Thanks,
Aaah, not sure you found the problem. The oil sending unit is just a fail safe for the fuel pump relay. When when oil is at operating pressure it alows voltage to be sent to the pump, for situations when the relay takes a dump. This allows you to get to your destinantion wqith a bad fuel pump relay. It's there as a back up for the relay
I'll try to help, Going off memory here so bare with me.
The connector that goes into the fuel tank sending unit contains three wires. Black is ground. A tan wire with a white tracer is the power wire going directly to the fuel pump do you have power at this location?
Remember unless your car is running you are only going to have power for two seconds after the key is turned to the run position. This is because the ECM only allows the pump to run for two seconds when the ignition is turned to the run position. The third wire is a power wire also; it is the one that is connected to the rheostat in your tank, it tells your gauge what fuel level to read depending on how much voltage it is receiving.
Check the fuel pump relay wires. The fuel pump relay is the middle relay on the passenger side fender. One of the wires connected to this relay is a dark green wire with a white tracer, located in pin A1 of the fuel pump relay wire harness socket assembly. When you turn the key to the run position the ECM triggers 12 volts for two seconds to the Dark green wire with a white tracer. In order to check this wire for power you will need some help. Get your test light on this lead and have your assistant turn the key to the run position, it should turn on the test light for two seconds, does it?
If the test light indicates you have power for two seconds then the internal Ecm relay is working. If it does not light then there is a problem with this circuit.
If it lights then turn the ignition key to off and probe the tan with white tracer wire plugged into the fuel pump relay (socket B).
Did it light up for two seconds?
If it did not light up check the black with white tracer, is it making a good ground?
If the ground is good and the tan with white tracer is not powering up you probably have a bad relay.
Hope this makes sense.
