Sorry for not checking back for such a long time. I just followed what he said to do, stick the wires into the A&E ports of the ALDL. I had to try it twice but it did come up. Don't use the 10K resistor between A&B; you don't need it and it will retard the timing like crazy (31° at idle on Scanmaster, not knock, just retard). As for the questions, here were mine:
1. When you open the program, it starts logging immediately. Is there any way to delay this so it can be started with the spacebar or something? And stopped as well with a key, preferably the spacebar?
2. On the Dash portion of the program, everything seems to work properly except the TPS voltage. Mine shows 9.8 when actually it is .42. It doesn't go up or down with changes in throttle position either. Also there is only a "tenths" reading on the main page for TPS. Can I adjust that to show hundredths?
Jonas said he would check out #2. He didn't have any advice for #1.
That's it.
A very slow update is what I noticed. It is probably no better than a Scanmaster so fine tuning with this program isn't going to happen like Turbolink (used it once) and it's light years behind DS from what I hear about DS (no experience). HTH
