Wilwood and gta wheels
Scarab
2 questions
1st does anyone know what totors theae are?
2nd Dows anyone know anything obout this type wheel. It seems to be or have a welded center
the rim is an 85-87 GTA (non dimpled spoke ends ) rim its 16x8 and came in front and rear offsets for use on the trans am , they were two piece rims with center welded to the drum ,,later dimpled GTAs were one piece. yours is a rear and has more backspace than the front version and would need a 1" spacer to use on the rear of a gbody ..most Gbody users install four front offset rims or put the rear gta rim on the front with a 3/16-1/4 spacer so it clears the steering tie rod end
the rotor looks like a raybestos drilled and slotted stock replacement
Found writing on inside.
Japan. Rear only. HOLO 5. 8JJX16. OFF 16. HH.
This is all the writing on the inside
More pictures
yes its a gta 16x 8 rear for trans am usage which had different front and rear offsets to work on that F-Body
, yes they were made in japan (theres a JWC logo on face )
i didnt ask for more pics i saw rear in your first set .. why all the pics?
To show they are welded together. I hate spacers but have not choice without replacing the wheel. I just inclided the pictures so someone could tell me about them. Being made in japan confused me.. sorry
I may have this set of wheels with like new front tires and new rear drag radials for sale soon. I am changing wheels and will not need them. It has 255/50/16 drag radials on the rear with 40 miles on them... like new.
