Sure they will I've done it several times but there needs to be a oil feed hole in the oil galleys to every lifter bore. You can even use a SBC lifter with a unshielded foot. The lifter galleys were not drilled when the blocks came from the factory but later done by the engine builder. Not all Stg11 motors oiled the rockers through the pushrods. This is easy to check of the intake is off the motor.
