which roller cam for my combo
tystick22
My combo will be as follows
stock block bored .20
center caps steel
girdle
balanced and blueprinted
te-66 ballbearing
art carr 19930 3500 stall
ported stock heads flow matched with 1.77 intake valves
ported intake with 70mm tb and precision doghouse
translator+ with 3.5" maf and extender chip
modded ecm for 72's
twin walboro 340's
T&D roller rockers (not sure what ratio yet)
Kenne Bell adjustable fuel regulator
3" thdp
jack cottons front mount
was thinking about the 214 steel kit from cottons or the 224-rol from precision though that ones sounds like a little much.
ATR 214-210 billet roller. my engine went 10's with Cotton driving when it was in another gn. he loves that cam grind.
The PTE 210/210 Billet roller seems to be a pretty good cam grind considering Roger Davis (Nashty) has gone 10.25 @131mph with it or maybe the 214/214 Billet roller cause Woody (azgn) has run 10.91 @123mph with it and that is with only 23lbs of boost and his combo is very close to yours (he has a TE-45A turbo which is basically a TE-66, 3600 stall converter, ported iron heads and intake, 214/214 Billet roller cam, 1.65 T&D roller rockers, V4, 55's, and the MaxEffort 16 Pos chip).... Hell there are guys going very fast (mid to low 10's @130+mph) with the 206/206 Billet roller cam so really I think any of them should work well with your combo so just buy one and go racing :)
cam
My son and I have the same steel billet roller. He has close to the same setup you have. His car went 10:68 @ 128 @ 26 psi. Mine is not intercooled so not as fast but still high 10/s @ 126. It is a Comp Cam 218--224 with .500 intake lift and .520 exhaust. Some people say it won/t work, I believe it does!!
Spend your money on getting the "toad" to 60ft.;) Buy a $100.00 flat tappet 206-206 , 212-212 , 218-218, Save $900.00 Smackers, and be done with it. I'm sure your Girl will appreciate all the movies, and fancy dinning .:D :D
Matt:cool:
OBTW, Your only about an hour from where I live.. You need to meet up with the buick guys from omaha one of these days, and go domminate the street races with us..:D
