Which recall sticker is on your GNX's radiator support
Anthony P
sharing knowledge with those who care to listen
I have a similar thread in the general tech section but not having much luck in finding the answer...GNX owners may be the best source for this answer.
In 1987 there were the two GM recalls for the non GNX turbo regals. One was for the brake switch and one was for the replacement of the aftermarket PROM chips relating to the failed emissions testing of those modified street driven cars.
One sticker is as represented in the attached pic while the other had a
letter/number code to the right of the "DO NOT REMOVE" text - something like "F 1028xx" in red text. The one with the code is pictured in Dennis Kirban's book Vol.2 tips, trivia... on page 38 (not a great picture and does not specify which recall).
From what I've been able to research, it was up to the GM mechanic whether or not to place the sticker on the radiator support (usually by the belt routing sticker or fan caution sticker). Some GM techs said that while we had the stickers, we never put them on. So...
Does anyone remember which sticker represents what recall? The GNX was only subject to the brake switch recall. So if a GNX has the recall sticker, it would be for the brake switch. If anyone has a chance, could they look to see which sticker they may have and post the answer. Thanks for the help.
recall sticker
Hi Anthony, The pic of the recall sticker you show is the is the only one I personaly seen and used, or rarely used. I have been with G.M. and Buick since 1980, and your right that those stickers were rarely put on.
The recalls that come to mind is, 87-C-14 prom replacements for Federal emissions only. 86-C-15 is for the powermaster pressure switch. 87-C-8 was for regals with 200-4R VIN break HP444387 to HP450102 for a manual valve linkage. Those stickers were paper, the tech would write the recall info then place a plastic film over it to protect it.
Hi Rod,
Thanks for the info. I've learned that a couple of the cars that Kirban's has for sale have the stickers on them. One has both. I'll have to schedule a trip when I'm in the area next month to get some pics. As a back-up plan, I should be able to get a picture of the other sticker (the one with the code on it) at Buick Performance Weekend at Raceway Park in NJ over the Labor day weekend. Hopefully by then I will have learned which sticker was for what recall and I will post the results and pics.
I have a few feelers out there with some other GNX owners. Cars are in storage so not readily available. I'll have something more to post when they can either get to the car or dig out some file pics that show the radiator support and sticker.
Turbofish38 posted the exacting details of PROM campaign 87-C-14 in the general tech thread. I have asked him to post the brake switch campaign details when has a chance. I was told that 87-C-13 was the brake switch campaign. Will have to cross-reference that with the 86-C-15 campaign - identical but had to be split by model year?
Hi Rod,
tony----i'm pretty sure that 87-C13 was the brake recall-------GNX's were exempted from the prom recall..............RC
86-c-15
#86-C-15: CAMPAIGN: POWERMASTER BRAKE SYSTEM/FAULTY PRESSURE SWITCH - (Oct 5, 1990)
SUBJECT: POWERMASTER BRAKE SYSTEM
MODELS AFFECTED: 1985 REGAL 3.8L TURBO (ENGINE VIN CODE 9) AND RPO LM9 BRAKES 1986-87 REGAL 3.8L TURBO (ENGINE VIN CODE 7) 1986 LESABRE AND ELECTR ESTATE WAGON 1986 CHEVROLET CAPRICE STATION WAGON 1986 PONTIAC PARISIENNE WAGON 1986 OLDSMOBILE CUSTOM CRUISER STATION WAGON
TO: ALL CHEVROLET DEALERS
** SEE BOTTOM OF CAMPAIGN FOR INFORMATION CONCERNING OTHER ** AFFECTED DIVISIONS.
GENERAL MOTORS HAS DETERMINED THAT CERTAIN 1986 CHEVROLET "B" STATION WAGONS WITH POWERMASTER BRAKE SYSTEMS WERE BUILT WITH COMBINATION VALVES AND PRESSURE SWITCHES WHICH MAY BECOME FAULTY. IF LEFT UNCORRECTED THESE VEHICLES MAY EXPERIENCE A "HARD BRAKE PEDAL" OR "INCREASED BRAKE PEDAL TRAVEL". THESE CONDITIONS MAY BE CAUSED BY A CAST IRON COMBINATION VALVE ALLOWING AIR TO ENTER THE BRAKE SYSTEM OR BY A PRESSURE SWITCH LEAKING BRAKE FLUID.
TO PREVENT EITHER OF THE ABOVE CONDITIONS FROM OCCURING, VEHICLES WILL BE INSPECTED AND THOSE EQUIPPED WITH THE CAST IRON COMBINATION VALVE WILL RECEIVE A NEW BRASS COMBINATION VALVE. ALSO, PRESSURE SWITCHES WILL BE INSPECTED AND REPLACED IF NECESSARY.
VEHICLES INVOLVED
INVOLVED ARE CERTAIN 1986 CHEVROLET "B" STATION WAGONS WITH POWERMASTER BRAKE SYSTEMS BUILT WITHIN THE FOLLOWING VIN BREAKPOINTS:
YEAR MODEL PLANT FROM THROUGH
1986 "B" WAGON FAIRFAX GX100001 GX207019
INVOLVED VEHICLES HAVE BEEN IDENTIFIED BY VIN COMPUTER LISTINGS. COMPUTER LISTINGS CONTAIN THE COMPLETE VIN, OWNER NAME AND ADDRESS DATA, AND ARE FURNISHED TO INVOLVED DEALERS WITH THE CAMPAIGN BULLETIN. OWNER NAME AND ADDRESS DATA FURNISHED WILL ENABLE DEALERS TO FOLLOW-UP WITH OWNERS INVOLVED IN THIS CAMPAIGN.
THESE LISTINGS MAY CONTAIN OWNER NAMES AND ADDRESSES OBTAINED FROM STATE MOTOR VEHICLE REGISTRATION RECORDS. THE USE OF SUCH MOTOR VEHICLE REGISTRATION DATA FOR ANY OTHER PURPOSE IS A VIOLATION OF LAW IN SEVERAL STATES. ACCORDINGLY, YOU ARE URGED TO LIMIT THE USE OF THIS LISTING TO THE FOLLOW-UP NECESSARY TO COMPLETE THIS CAMPAIGN. ANY DEALER NOT RECEIVING A COMPUTER LISTING WITH THE CAMPAIGN BULLETIN HAS NO INVOLVED VEHICLES CURRENTLY ASSIGNED.
OWNER NOTIFICATION
OWNERS WILL BE NOTIFIED OF THIS CAMPAIGN ON THEIR VEHICLES BY CHEVROLET MOTOR DIVISION (SEE COPY OF OWNER LETTER INCLUDED WITH THIS BULLETIN).
DEALER CAMPAIGN RESPONSIBILITY
DEALERS ARE TO SERVICE ALL VEHICLES SUBJECT TO THIS CAMPAIGN AT NO CHARGE TO OWNERS, REGARDLESS OF MILEAGE, AGE OF VEHICLE, OR OWNERSHIP, FROM THIS TIME FORWARD.
WHENEVER A VEHICLE SUBJECT TO THIS CAMPAIGN IS TAKEN INTO YOUR NEW OR USED VEHICLE INVENTORY, OR IT IS IN YOUR DEALERSHIP FOR SERVICE IN THE FUTURE, YOU SHOULD TAKE THE STEPS NECESSARY TO BE SURE THE CAMPAIGN CORRECTION HAS BEEN MADE BEFORE RESELLING OR RELEASING THE VEHICLE.
OWNERS OF VEHICLES RECENTLY SOLD FROM YOUR NEW VEHICLE INVENTORY ARE TO BE CONTACTED BY THE DEALER, AND ARRANGEMENTS MADE TO MAKE THE REQUIRED CORRECTION ACCORDING TO INSTRUCTIONS CONTAINED IN THIS BULLETIN.
PARTS INFORMATION
PARTS REQUIRED TO COMPLETE THIS CAMPAIGN ARE TO BE OBTAINED FROM GMSPO. TO ENSURE THESE PARTS WILL BE OBTAINED AS SOON AS POSSIBLE, THEY SHOULD BE ORDERED FROM GMSPO ON A "C.I.O." ORDER WITH NO SPECIAL INSTRUCTION CODE, BUT ON AN ADVISE CODE 2.
QUANTITY/ PART NUMBER DESCRIPTION VEHICLE
25509419 BRASS COMBINATION VALVE 1
18018141 PRESSURE SWITCH (INCLUDES O-RING) 1
SERVICE PROCEDURE
1. INSPECT PRESSURE SWITCH. IF THE CURRENT PRESSURE SWITCH IS GRAY, MOVE ON TO STEP 2. IF THE CURRENT SWITCH IS BLACK, REMOVE AND REPLACE PRESSURE SWITCH ACCORDING TO THE PROCEDURE BELOW AND THEN MOVE ON TO STEP 2.
A. DEPRESSURIZE POWERMASTER UNIT BY TURNING IGNITION "OFF", AND APPLY AND RELEASE BRAKE PEDAL A MINIMUM OF TEN (10) TIMES USING APPROXIMATELY FIFTY (50) POUNDS OF FORCE ON PEDAL TO FULLY DEPLETE THE POWER ASSIST.
NOTICE: FAILURE TO FULLY DEPRESSURIZE POWERMASTER UNIT COULD RESULT IN BRAKE FLUID BEING SPRAYED ON SERVICE PERSONNEL AND COULD CAUSE DAMAGE TO PAINTED SURFACES.
B. DISCONNECT 3-WIRE ELECTRICAL CONNECTOR (FIG. 1, 40) FROM PRESSURE SWITCH (FIG. 1, 1).
C. REMOVE OLD PRESSURE SWITCH (FIG. 1, 1).
D. LUBRICATE NEW O-RING (FIG. 1, 2) WITH CLEAN, FRESH BRAKE FLUID AND INSTALL ON NEW PRESSURE SWITCH.
E. INSTALL NEW PRESSURE SWITCH (FIG. 1, 1), TIGHTEN TO 20-27 NM (15-20 LB. FT.).
NOTICE: TORQUE VALUES SPECIFIED ARE FOR DRY, UNLUBRICATED FASTENERS.
F. RECONNECT 3-WIRE ELECTRICAL CONNECTOR (FIG. 1, 40) TO PRESSURE SWITCH (FIG. 1, 1). BE SURE ELECTRICAL CONNECTOR IS SECURELY SEATED.
2. LOCATE COMBINATION VALVE (ON FRAME RAIL BELOW MASTER CYLINDER). IF THE CURRENT COMBINATION VALVE IS THE POTENTIALLY FAULTY CAST IRON VALVE TYPE THE VALVE MUST BE REPLACED WITH A BRASS VALVE TYPE BY FOLLOWING THE PROCEDURE BELOW. IF THE VEHICLE ALREADY HAS THE BRASS VALVE, THE COMBINATION VALVE DOES NOT NEED TO BE REPLACED. PROCEED TO STEP 3. FIGURE 2 ON THE NEXT PAGE ILLUSTRATES THE DIFFERENCES IN THE TWO VALVE TYPES.
A. REMOVE THE ELECTRICAL WARNING HARNESS CONNECTOR FROM THE PRESSURE DIFFERENTIAL SWITCH BY SQUEEZING THE ELIPTICAL-SHAPED PLASTIC LOCK RING AND PULLING UP. A PAIR OF PLIERS MAY AID IN REMOVING THE CONNECTOR.
B. DISCONNECT HYDRAULIC LINES AT COMBINATION VALVE. PLUG LINES TO PREVENT LOSS OF FLUID AND ENTRANCE OF DIRT.
C. REMOVE POTENTIALLY FAULTY CAST IRON COMBINATION VALVE.
D. INSTALL BRASS COMBINATION VALVE. TORQUE MOUNTING BOLTS TO 20 NM (14 LB. FT.).
E. CONNECT WARNING HARNESS SWITCH TO VALVE SWITCH TERMINAL.
F. REMOVE PLUGS AND CONNECT HYDRAULIC LINES AT COMBINATION VALVE. TORQUE LINES TO 24 NM (18 LB. FT.).
G. CONNECT ELECTRICAL WARNING HARNESS CONNECTOR TO PRESSURE CONTROL DIFFERENTIAL SWITCH.
H. BLEED ENTIRE BRAKE SYSTEM. DO NOT MOVE VEHICLE UNTIL A FIRM BRAKE PEDAL IS OBTAINED.
I. CHECK BRAKE LINES FOR PROPER CLEARANCES.
3. INSTALL CAMPAIGN IDENTIFICATION LABEL.
EACH VEHICLE CORRECTED IN ACCORDANCE WITH THE INSTRUCTIONS OUTLINED IN THIS PRODUCT CAMPAIGN BULLETIN WILL REQUIRE A "CAMPAIGN IDENTIFICATION LABEL." EACH LABEL PROVIDES A SPACE TO INCLUDE THE FIVE (5) DIGIT DEALER CODE OF THE DEALER PERFORMING THE CAMPAIGN SERVICE. THIS INFORMATION MAY BE INSERTED WITH A TYPEWRITER OR A BALL POINT PEN.
EACH "CAMPAIGN IDENTIFICATION LABEL" IS TO BE LOCATED ON THE RADIATOR CORE SUPPORT IN AN AREA WHICH WILL BE VISIBLE WHEN THE VEHICLE IS BROUGHT IN FOR PERIODIC SERVICING BY THE OWNER.
APPLY "CAMPAIGN IDENTIFICATION LABEL" ONLY ON A CLEAN DRY SURFACE.
CLAIM INFORMATION
SUBMIT A PRODUCT CAMPAIGN CLAIM WITH THE INFORMATION INDICATED BELOW: * FAILED PARTS LABOR LAB OTH REPAIR PERFORMED PC PART NO. ALLOW CC-FC OP. HRS HRS
INSPECT - NO - -- -- SK-00 V6160 0.2 0.1 REPLACEMENT NEEDED PRESSURE SWITCH OR COMBINATION VALVE ------------------------------------------------------------------ INSPECT COMBO VALVE 1 18018141 ** SK-00 V6161 0.4 0.1 + PRESSURE SWITCH. REPLACE PRESSURE SWITCH ONLY. ------------------------------------------------------------------ INSPECT COMBO VALVE 1 25509419 ** SK-00 V6162 0.9 0.1 + PRESSURE SWITCH. REPLACE COMBO VALVE ONLY. ------------------------------------------------------------------ INSPECT/REPLACE 2 25509419 ** SK-00 V6163 1.2 0.1 COMBO VALVE AND PRESSURE SWITCH ------------------------------------------------------------------
* CAMPAIGN ADMINISTRATIVE ALLOWANCE
** THE "PARTS ALLOWANCE" SHOULD BE THE SUM TOTAL OF THE CURRENT GMSPO DEALER NET PRICE PLUS 30% OF ALL PARTS REQUIRED FOR THE REPAIR.
DEALERS WILL AUTOMATICALLY RECEIVE THE CORRECT LABOR AND MATERIAL ALLOWANCE BASED ON THE LABOR OPERATION PERFORMED.
REFER TO THE CHEVROLET CLAIMS PROCESSING MANUAL FOR DETAILS ON PRODUCT CAMPAIGN CLAIM SUBMISSION.
REIMBURSEMENT
CUSTOMER REQUESTS FOR REIMBURSEMENT OF PRIOR REPLACEMENT OF THE POWERMASTER BRAKE ASSEMBLY ARE TO BE SUBMITTED ACCORDING TO THE FORMS AND INSTRUCTIONS INCLUDED IN THIS BULLETIN (ADDITIONAL COPIES TO BE REPRODUCED LOCALLY) WITHIN 3 MONTHS (90 DAYS) OF THE DATE OF THEIR OWNER LETTER. OWNERS MUST SUBMIT ORIGINAL DOCUMENTATION THAT REASONABLY CONFIRMS THE AMOUNT OF UNREIMBURSED REPAIR EXPENSES, A DESCRIPTION OF THE REPAIR, THE DATE OF THE REPAIR, AND THE PERSON OR ENTITY PERFORMING THE REPAIR TO RECEIVE REIMBURSEMENT.
COPYRIGHT 1990 CHEVROLET MOTOR DIVISION GENERAL MOTORS CORPORATION ALL RIGHTS RESERVED
** BUICK INFORMATION ONLY:
VEHICLES INVOLVED
INVOLVED ARE CERTAIN 1985, 1986 AND 1987 REGAL 3.8L TURBO ENGINE COUPES AND 1986 LESABRE AND ELECTRA ESTATE WAGONS WITH POWERMASTER BRAKE SYSTEM BUILT WITHIN THE FOLLOWING VIN BREAKPOINTS
YEAR MODEL PLANT FROM THROUGH 1985 REGAL TURBO COUPE PONTIAC FP400004 FP427709 1986 REGAL TURBO COUPE PONTIAC GP201039 GP459261 1986 ESTATE WAGON FAIRFAX GX400001 GX418126 1987 REGAL TURBO COUPE PONTIAC HP400001 HP465289
BUICK CLAIM INFORMATION
SUBMIT A PRODUCT CAMPAIGN CLAIM WITH THE INFORMATION INDICATED BELOW: * FAILED PARTS LABOR LAB OTH DLR. OPER. PC PART NO. ALLOW CC-FC OP. HRS HRS MTL TWG ------------------------------------------------------------------ - -- -- 96 V6160 0.2 0.1* ----
INSPECT - NO REPLACEMENT NEEDED - PRESSURE SWITCH OR COMBINATION VALUE
1 18018141 ** 96 V6161 0.4 0.1* ----
INSPECT AND REPLACE PRESSURE SWITCH ONLY (ALL INVOLVED VEHICLES)
1 25509419 ** 96 V6162 0.9 0.1* 2.86***
INSPECT AND REPLACE COMVINATION VALUE (1986 LESABRE AND ELECTRA ESTATE
2 25509419 ** 96 V6163 1.2 0.1* 2.86***
INSPECT AND REPLACE PRESSURE SWITCH AND COMVINATION VALUE (1986 LESABRE AND ELECTRA ESTATE WAGON ONLY) ------------------------------------------------------------------ - -- -- 96 T1640 (SEE INSTRUCTIONS FOR REIMBURSEMENT) REIMBURSEMENT FOR PREVIOUSLY CUSTOMER PAID REPAIRS ------------------------------------------------------------------
* DEALER ADMINISTRATION ALLOWANCE ** LIST CURRENT DEALER PRICE, PLUS 30% *** MATERIAL ALLOWANCE FOR HYDRAULIC BRAKE FLUID (DOT 3)
BUICK REQUEST FOR REIMBURSEMENT INSTRUCTIONS
1. CUSTOMER PRESENTS DEALER WITH ORIGINAL PAID RECEIPTS COVERING REPAIRS.
2. DEALER COMPETES A REPAIR ORDER (R.O.) SHOWING THE FOLLOWING - REPAIR ORDER DATA - VEHICLE IDENTIFICATION NUMBER - CURRENT MILEAGE - OWNER'S ADDRESS - ATTACHES ORIGINAL OWNER'S OR DEALER'S PAID INVOICES/RECEIPTS REPAIR - USE LABOR OPERATION NUMBER T1640 AND FAILURE CODE 96 - ENTER TOTAL OF REIMBURSEMENT BASED ON 100% OF OWNERS EXPENSE
3. OWNER SIGNS THE REPAIR ORDER AS ACKNOWLEDGEMENT OF REQUESTED REIMBURSEMENT AMOUNT.
4. OWNER IS GIVEN A COPY OF REPAIR ORDER.
5. DEALER ASSIGNS A WARRANTY MANAGEMENT SYSTEM (WMS) AUTHORIZATION CODE TO THE CLAIM AND ENTERS IT ON THE WMS AUTHORIZATION LOG.
6. THE DEALER SUBMITS A CLAIM TO BUICK FOR PROCESSING
7. DEALER ISSUES THE OWNER A REIMBURSEMENT CHECK FOR THE APPROVED AMOUNT. THE CHECK NUMBER MUST BE ENTERED ON THE REPAIR ORDER AND A COPY OF THE CHECK MUST BE ATTACHED TO ORIGINAL PAID INVOICES RECEIPTS.
8. ALL SUPPORTING DOCUMENTATION MUST BE AVAILABLE FOR REVIEW BY BUICK
NOTICE: REFER TO BUICK SERVICE POLICIES AND PROCEDURE MANUAL, SECTION 1.6.11 FOR SPECIFIC PROCEDURES FOR CUSTOMER REIMBURSEMENT VERIFICATION.
IN THE EVENT THE DEALER SERVICE MANAGER AND THE OWNER CANNOT REACH AGREEMENT ON AMOUNT ELIGIBLE FOR REIMBURSEMENT AFTER REVIEW OF INVOICES/RECEIPTS, THE ZONE/BRANCH SHOULD BE CONTACTED FOR DETERMINATION OF COVERED EXPENSES. IN SUCH CASES, AN EXPLANATION SHOULD BE INCLUDED ON THE R.O.
** PONTIAC INFORMATION ONLY:
VEHICLES INVOLVED
INVOLVED ARE CERTAIN 1986 PONTIAC PARISIENNE STATION WAGONS WITH POWERMASTER BRAKE SYSTEMS BUILT WITHIN THE FOLLOWING VIN BREAKPOINTS:
YEAR MODEL FROM THROUGH 1986 FAIRFAX GX200005 GX285088
PONTIAC CLAIM INFORMATION:
A SEPARATE REPAIR ORDER MUST BE USED FOR EACH VEHICLE. A COMPLETED WARRANTY CLAIM IS TO BE KEPT AS A PERMANENT RECORD OF COMPLETION.
DEALERS SHOULD SUBMIT WARRANTY CLAIMS FOR CREDIT IN THEIR NORMAL MANNER WHEN THEY PERFORM THE SERVICE AS FOLLOWS:
OTHER* FAILURE LABOR LABOR LABOR OPERATION CODE OPERATION HOURS HOURS -------------- --------- --------- ------- -------- INSPECT PRESSURE SWITCH AND COMBINATION VALUVE-NO REPLACEMENTS NEEDED 96 V6160 0.2 0.1
INSPECT COMBINATION VALVE AND PRESSURE SWITCH-REPLACE PRESSURE SWITCH ONLY 96 V6161 0.4 0.1
INSPECT COMBINATION VALVE AND PRESSURE SWITCH-REPLACE COMBINATION VALVE ONLY 96 V6162 0.9 0.1
INSPECT/REPLACE COMBINATION VALVE AND PRESSURE SWITCH 96 V6163 1.2 0.1
OWNER REIMBURSEMENT FOR PRIOR REPLACEMENT OF THE POWERMASTER BRAKE ASSEMBLY, COMBINATION VALVE, AND/OR PRESSURE SWITCH 95 T1640 --- ---
* IN ADDITION, DEALERSHIPS WILL RECEIVE 0.1 HOURS CREDIT FOR DEALER ADMINISTRATIVE SERVICES ASSOCIATED WITH THIS CAMPAIGN. THE 0.1 HOURS ALLOWANCE IS TO BE ENTERED IN THE 'OTHER LABOR HOURS' FIELD WITH EACH CAMPAIGN REPAIR LISTED FOR CREDIT. THIS ENTRY WILL NOT REQUIRE AUTHORIZATION.
FAILURE CODE 96 MUST BE USED WITH THE LABOR OPERATION.
PARTS REQUIRED ARE TO BE LISTED IN YOUR WARRANTY CLAIM IN THE NORMAL MANNER. PARTS WILL BE CREDITED AT DEALER NET PLUS 30% DEALER HANDLING ALLOWANCE.
DEALERS WILL BE CREDITED VIA WARRANTY DOCUMENT OR TERMINAL TRANSMISSION, WHICHEVER IS THEIR NORMAL METHOD OF SUBMISSION FOR PAYMENT. CLAIM MUST CONTAIN ALL INFORMATION REQUIRED AND SHOULD LIST THE LABOR OPERATION AS OUTLINED.
** OLDSMOBILE INFORMATION ONLY:
VEHICLES INVOLVED
YEAR MODEL FROM THROUGH MODEL NAME 1986 'B' WAGON GX200005 GX285088 CUSTOMER CRUISER
OLDSMOBILE CLAIM INFORMATION:
SUBMIT CLAIMS USING NO MORE THAN ONE OF THE 'V' LABOR-OPS BELOW FOR EACH VEHICLE. AS APPROPRIATE, BOTH A 'T' LABOR OP AND ONE 'V' LABOR- OP MAN BE SUBMITTED ON A VEHICLE.
FAILURE LABOR LABOR OPERATION CODE OPERATION HOURS TOT-PTS -------------- --------- --------- ------- ------- INSPECT PRESSURE SWITCH OR COMBINATION VALUVE-NO REPLACEMENTS NEEDED 96 V6160 0.2*
INSPECT COMBINATION VALVE AND PRESSURE SWITCH-REPLACE PRESSURE SWITCH ONLY 96 V6161 0.4*
INSPECT COMBINATION VALVE AND PRESSURE SWITCH-REPLACE COMBINATION VALVE ONLY 96 V6162 0.9*
INSPECT/REPLACE COMBINATION VALVE AND PRESSURE SWITCH 96 V6163 1.2*
OWNER REIMBURSEMENT FOR PRIOR REPLACEMENT OF THE POWERMASTER BRAKE ASSEMBLY, COMBINATION VALVE, AND/OR PRESSURE SWITCH (PRIOR ZONE AUTHORIZATION REQUIRED 96 T1640 ---
* .1 HOUR FOR CLERICAL ADMINISTRATION MAY BE ADDED TO THE PUBLISHED LABOR HOURS.
PARTS ALLOWANCE: CURRENT DEALER PRICE, PLUS 30% HANDLING ALLOWANCE.
THE COST OF BRAKE FLUID MAY BE APPLIED FOR IN THE USUAL MANNER.
**GENERAL MOTERS DISCLAIMER***
Figure 1
Figure 2
Figure 3
Figure 4
General Motors bulletins are intended for use by professional technicians, not a "do-it-yourselfer". They are written to inform those technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions and know-how to do a job properly and safely. If a condition is described, do not assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See a General Motors dealer servicing your brand of General Motors vehicle for information on whether your vehicle may benefit from the information.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
87-c-13
#87-C-13: CAMPAIGN: POWERMASTER BRAKE SYSTEM/FAULTY PRESSURE SWITCH - (Oct 5, 1990)
VEHICLES INVOLVED
OWNER NOTIFICATION
PARTS INFORMATION
SERVICE PROCEDURE
CLAIM INFORMATION
REIMBURSEMENT
VEHICLES INVOLVED
VEHICLES INVOLVED
VEHICLES INVOLVED
Figure 1
Figure 2
Figure 3
Figure 4
86-C-15 and 87-C-13
Looks like both 86-C-15 and 87-C-13 apply. I got the above info from G.M. S.I. I would like to see pics of the other sticker, may jog some archive file in my head.
from my quick glance thru some of that, i saw some Chevrolet "B" station wagons mentioned as having the powermaster setup..
is this true? i've never heard of it on anything besides 86 and 87 turbocharged Buicks.
the "problem master" brake system was used on quite a few cars years before it ever appeared on the turbo regals---------and it was used on late 85 GN's as well as 86/87's
Hi Mr. Clark,
Thanks for your earlier e-mail and follow up here. With the help from Rod and Eric Fisher, I now have the exacting details for each of the campaigns. And we now know that each campaign had a sticker. I just don't know which sticker yet. That's why I'm trying the GNX route. If a GNX has the recall sticker, we know it would be for the brake switch. Then we could conclude if the posted sticker image is the same as what's on the GNX, that sticker was for the brake switch campaign.
By process of elimination, the other almost identical sticker that has the "F 102xxxx" code must be for the emissions recall.
Hi Rod,
Thanks for posting the exacting details of the campaigns. Now we know that each campaign had a sticker. I found of a car for sale that is listed as having the brake switch recall sticker. I have contacted the seller and am waiting for a reply. I also found another car for sale that has both recall stickers. I'm waiting for the reply on the picture request.
The only picture I have of the other sticker is the not so great scanned image from Dennis' book. But you can see there is the code printed on the right side while the good pic I posted does not have the code.
Some might say I have a lot of time on my hands to be pursuing this. It's just one more thing to know. Heck, it took me a few years to get a good handle on the sequential build #'s for the '86 and '87 turbo regals.
I scanned that page from Dennis' book. I know it's not great quality but does it ring any bells?
  • F code recall sticker.PDF
Hi Mr. Clark,
Hi Rod,
i had all my GNX recalls done at the same time----i went to the dealer but the two cars that had less than 6 miles i did not even take to the dealer--------since i knew him so well he just entered the data and gave me the parts and the stickers for the lower mileage cars since i wouldn't let a mechanic near them and i didn't want the stickers stuck on the radiator support-------i still have the stickers in a bag with the parts and when i remember to dig them up i will scan them in a high resolution scanner so you can repo them if you want.............RC
Hi Mr. Clark,
thanks for the offer. It is probably not a bad idea to have a hi-res image in the files for future use someday.
Eric Fisher (turbofish38) confirmed that his '86 GN has the sticker I posted the image of for his brake switch recall.
Now to finalize the "F" coded sticker details. Time will tell if the code was the same for all stickers. I know there will be a good 1/2 dozen cars with this sticker racing at Englishtown's Buick Performance event this labor day weekend. Maybe that is the giveaway - all the cars I've seen with this F code sticker are racers?
