....... I don't want to bother the heads other than replacing the valve springs and lifters just want to bump up from stock since I have to put a timing chain in it.. Thanks for any advice.. I hear a 206/206 or a 204/214
This is typical thinking from someone new to turbo cars, especially GN's.
First of all you will see no gain in performance from the cam change you plan.
What many people, both turbo and NA, fail to understand is it is all about the combination of parts and work to achieve an overall performance level. This is ESPECIALLY true when dealing with forced induction engines.
The one thing you mention that you do NOT want to have done is you "don't want to bother with the heads"?
This is where the power comes from, more air, more fuel, equals more power. That is the one area where you can get more power for the least $$$ expended.
For 25 years we have developed "recipes" of how to efficiently increase performance, and do it with a minimal budget, but the newer generation could care less about history lessons, but they want to break new ground.
You need to begin where I tell my customers, first determine your performance goal and see if that will fit your budget, not just throw some parts under the hood to go faster.
