TurboTdanman
- Dec 3, 2011
I currently have a weak fuel pump which is a walbro 340.
I would really like to go to running E85 since 110 racing gas is so expensive its not cost effective for me.
I currently have a PT-61 turbo, built motor, not sure what cams in the car since i bought it this way, champion ported irons, accufab 70mm tb and plenum and im running 25lbs of boost. I have 55lb injectors.
Im just wondering your expert opinions on what i would need for a fuel system if i wanted to switch to E85.
is a single pump good enough to supply enough fuel for E85? what lb injectors would i need to run E85 with my set up.
Or is it recommended to go with a double pumper and alot bigger injectors?
im on the stock ECM also with a TT chip.
Thanks guys!
Thanks guys!
