Call Dave Husek, i wouldnt mess around with any other 2004r trans+converter guy no offence, its a simple 6 hr drive from you, save a ton in shipping, i'll even meet you at his shop and go over the whole combo, hes 20 min away from me.Yeah I’ve known the guy for many years it does come up on google so I don’t know what’s up with that but maybe the name or something is slightly different. He’s really good and has Owned 3/4 of these, he knows his way around a tranny and I’ve known him forever. Also I do have a shift kit in it but the disks in the transmission are shot, the car sat for over 15-20 years so once I got it pushing the power it should she just giving up.
Also yes I did have that hooked up lol I’m gonna disconnect that, I’m gonna order the kit and wash out my intercooler if that’s possible.
One problem with using a 30+ y/o cooler assy is the efficiency has probably taken a hit... Maybe a significant hit. Heat cycles, vibration, environment, all affect the integrity of the fin to tube connection. Accumulated dirt inside doesn't help.
AIRC, when new, the units were only about 58% efficient.
I'm wondering if a vertical flow unit would be more efficient.
Once an old unit is "renovated", cut, welded, and properly cleaned, just how much is invested vs a new core? Don't know.
Back under my rock.
Your not the lastI'm the last of Grumpy's Keep It Simple Stupid crew that drag the most from the least. Think I'm gonna sit on the side lines and watch from here on in like you do
OP should just put a stage motor in itMy dyno tests:
3 pulls each. Open dump and closed dump.
ATR headers & exh system, dual muffs and dp. My dump.
Avg RWHP diff was +/- 5.
Boost was mid 20's, made close to 650 AIRC.
Anyway, enough to push a 3750# turd to 144 mph.
No, it was not a 109....
with lots of consideration I will probably be around the 19-21 psi range. What do I need to do to achieve the 400hp mark, do I need to do any serious mods to the motor or timing chain to support this power. Also what valve springs should I go with 980-12s or something else. I did have a list in a earlier post of mods I have and plan on doing. I will re post my list after this post. Thanks to everyone for their ideas and help. I really appreciate it.Threads a bit off track, im just reading into a 17 year olds mind, no way hes gonna be satisfied with 17 psi with these cars, its not a forced induction big block where your at quadruple digits at 17, its a stock lc2 hovering around 300 so it comes down toooo...What does he really want to do with the car... then the proper combo can be written
Boost and octane will achieve 400hp, if your stock turbo is finished i would do a Mfs 58mm, double roller timing chain,3" dp,test pipe, alky kit+chip,100lb valve springs, power logger and most importantly a converter spec'd to the comboOk with lots of consideration
How important for a timing chain, like my car is 32k miles is it really important. Im just not sure? ThanksBoost and octane will achieve 400hp, if your stock turbo is finished i would do a Mfs 58mm, double roller timing chain,3" dp,test pipe, alky kit+chip,100lb valve springs, power logger and most importantly a converter spec'd to the combo
Ok I’ll look into a new one for sureI had spider cracks in mine at 35k miles. It's 33 year old plastic.
100% post 118, stock one is plasticHow important for a timing chain, like my car is 32k miles is it really important. Im just not sure? Thanks
