Well, NHRA says you need C clip eliminators in the 10's (sorry, having a brain fade and can't remember the exact et but it is either 11.50 or 10.99). I have one friend who broke an axle when he was in the 13's, and that was exciting enough just to hear about it. I'm not that quick yet but I had an axle seal start leaking and the axle was scarred so I needed new ones anyway so I had my rear rebuilt with moser 30 spline axles, eaton 30 spline posi, and the Ford weld on ends. The axles are all the same price and you have to buy axles with c clip elinators so it's no more expensive there. The ends are about $150 and then the labor to get them welded on by a shop that has the right fixture to keep it all straight. Then you need brakes. I went with the lowest cost, loaded 9"x2" Ford drum brakes. Again, you just tell them what lug pattern you want on the axles and drums, there is no extra cost, so my TR wheels bolt right up. I was shocked but with a little finagling to get the emergency brake cables threaded through the Ford backing plate they hooked right up and didn't even need adjusting. So, I think the brakes were $300, the ends $150, and the extra to get them welded on was maybe $300?, and now I have a legal rear that will never leak and has much beefier axle bearings than the c clip eliminators. The rear brakes stop really well, and are a good complement to the front B Body brake upgrade with 12" rotors. With a 3000ish stall Yank 9" converter I could easily hold 18-20 psi of boost at 3500 rpm on the footbrake. Too bad the Nittos would only hold 4-5 psi
. There are disc brake options, I think from an Explorer, that would add several hundred more $$ if you want to got that way. Anyway, I just didn't want any part of the leaks and frequent bearing replacement of the c clip eliminators (I was told by a Moser engineer that their c clip eliminators would need new seals and bearings every 8-10,000 miles on the street). Oh, you can go with the 70's A body ends and brakes, but I think the Ford parts are beefier and the brakes better and all the parts are readily available, just get shoes and drums for a big station wagon from the 80's.
