So I'm planning to head back to the track in 2 weeks. Last time out was in February and I ran a 12.12 @ 112.8 with a 1.88 60' time. Launched at zero psi with 22 or 23 psi boost. I had the front sway bar loose and the car was a little spooky on the big end.
Since then I've added s10 wheel cylinders and I've been able to hold 5 psi boost just testing it on the street. I've also replaced the timing chain, installed LS1 maf and translator and upgraded from 42lb to 60lb injectors. I'd love to launch it at 5 psi but I'm not sure if the bfg drag radials will hook. Wish I had mickey's for the track but the bfg's have been a good street tire.
So I'm thinking ... three second burnout, launch at maybe 3 psi boost for starters, 10 psi in right side air bag, 18 psi in the tires. I have the car tuned for 25 psi right now and it's running great.
Any tips are greatly appreciated guys.
